[Vorschau] Logos machen
Beitragvon Supersuzi » Fr 16. Mär 2012, 19:39
Bumpy
bekommst du hier
ChromSparkle
ist das hier
electricity
wäre der hier
Text Blend
ist das hier
glass
das finde ich grad nicht, deshalb fühe ich es mal an, wenn das so nicht richtig ist, dann bitte löschen :angel:
speichern als: Logo-glass.scm
Ausgeblendet:
; This program is free software; you can redistribute it and/or modify
; it under the terms of the GNU General Public License as published by
; the Free Software Foundation; either version 2 of the License, or
; (at your option) any later version.
; This program is distributed in the hope that it will be useful,
; but WITHOUT ANY WARRANTY; without even the implied warranty of
; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
; GNU General Public License for more details.
; You should have received a copy of the GNU General Public License
; along with this program; if not, write to the Free Software
; Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
(define (set-pt arr i x y)
(aset arr (* i 2) x)
(aset arr (+ (* i 2) 1) y)
(define (glass-sketch)
(let*
((a (cons-array 18 'byte)))
(set-pt a 0 0 0)
(set-pt a 1 127 32)
(set-pt a 2 255 64)
a))
(define (glass inimage indraw thickness displace delete)
(gimp-context-set-foreground '( 255 255 255))
(let*(
(theImage inimage)
(theDraw indraw)
(height (car (gimp-image-height theImage)))
(width (car (gimp-image-width theImage)))
(layer2 (car (gimp-layer-copy theDraw 1)))
(layer3 (car (gimp-layer-new theImage width height 1 "layer3" 100 0)))
(gimp-image-undo-group-start theImage)
(gimp-image-add-layer theImage layer2 -1)
(gimp-drawable-fill layer3 3)
(gimp-image-add-layer theImage layer3 -1)
(gimp-selection-layer-alpha layer2 )
(gimp-edit-bucket-fill layer2 0 0 100 0 0 0 0)
(gimp-context-set-foreground '( 132 106 79))
(gimp-edit-bucket-fill layer3 0 0 100 0 0 0 0)
(gimp-selection-none theImage)
(plug-in-gauss 1 theImage layer2 5 5 1)
(plug-in-bump-map 1 theImage layer3 layer2 135 45 (+ thickness 2) 0 0 0 0 0 0 0)
(gimp-selection-layer-alpha layer3 )
(gimp-selection-shrink theImage thickness)
(gimp-selection-feather theImage (- thickness 1))
(gimp-curves-spline layer3 4 6 (glass-sketch))
(let*(
(layer4 (car (gimp-layer-copy layer3 1)))
(gimp-image-add-layer theImage layer4 -1)
(gimp-edit-clear layer3)
(gimp-invert layer4)
(plug-in-gauss 1 theImage layer3 (+ 2 displace) (+ 2 displace) 1)
(gimp-drawable-offset layer3 1 0 displace displace)
(gimp-hue-saturation layer4 0 0 0 -100)
(gimp-image-remove-layer theImage layer2)
(gimp-drawable-set-visible theDraw 0)
(if (= delete TRUE) (gimp-image-remove-layer theImage theDraw))
(gimp-layer-set-mode layer3 BURN-MODE)
(gimp-layer-set-opacity layer3 86)
(gimp-image-undo-group-end theImage)
(gimp-displays-flush)
(script-fu-register "glass"
"<Image>/Script-Fu/Logo/glass"
"Turns a layer into glass"
"Karl Ward"
"Karl Ward"
"May 2008"
"RGBA"
SF-IMAGE "SF-IMAGE" 0
SF-DRAWABLE "SF-DRAWABLE" 0
SF-ADJUSTMENT "Glass Thickness" '(3 1 10 1 2 0 1)
SF-ADJUSTMENT "Shadow Displacment" '(12 5 24 1 2 0 1)
SF-TOGGLE "Delete original layer" TRUE
:kaffee: ..... :pc: meine Tuts :augly: ...... :wein:
Re: [Vorschau] Logos machen
Beitragvon Supersuzi » Fr 16. Mär 2012, 19:40
xtns-mosteller-multi-effect-text
xtns-lankinen-fiery-steel
xtns-mosteller-lava-logo
madsen-fire-animator
Letter drop
alle hier drin
bling-text
hab ich von hier
